Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
xgen density maps not working fine
6 REPLIES 6
ray
8140 Views, 6 Replies
Hello I always have problems with xgen density maps. I paint a black and white map with no blur on the edges, when I update there are some hairs on the black areas too. Few hairs but they are present.
I followed a tutorial that suggested to paint maps in mudbox and so I did. But the problem is still there, even if I paint in ptex. Is someone experiencing the same problem ?
Thank you
Ray
6 REPLIES 6
ray
in reply to: ray
Is it just me on this forum ?
Michael_Todd
in reply to: ray
The only issue with density maps painted in Maya is the fact that the soft falloff brush only paints true black at the very center of the brush. It looks like it's paint black with soft edges but the falloff actually starts right at the center. It's best to use a hard edged brush then blur the edges.
Make sure the brush opacity is not set to a lower value as well.
The falloff issue is not really a problem in mudbox if you are painting true black, but brush opacity and the falloff settings could still cause issues if the values are preventing true black from being painted in the map.
Michael Todd
XGen Product Owner and Designer
in reply to: ray
Thank you
Ray
Hello! I know this thread says solved and I'm 2 years late but I had the same issue. I painted and painted and painted pure black with the hard brush in Maya, checked the map in Photoshop... at the end the answer was to turn off the Stylus Pressure, -.-
keep only fur uv set in mesh on which fur is grown. if there are multiple uv maps, the maps wont give needed result what i found recently
Chtenelis
in reply to: ray
Try to flood with black first.
ratherwilde
Thanks for coming back to say what fixed it, been going crazy all night with the same issue! Pen Pressure fixed it. Thanks god 😄
