Xgen. connect 32bit Tiff displacement to Xgen
dima.teslenko88
dima.teslenko88
Hi!
I have a groom work just for learning Xgen and when I have done all groom work on lion model I got a problem with the displacement map. I have a lot of descriptions so I create an expression for displacement and when I try to load a displacement map with 32bit tiff format it goes me to error...
How can I connect this kind of displacement map to Xgen or if it's not possible, please, tell me what I am should learning and which way I am should digging:)
Thanks!
Replies (7)
sean.heasley
Hi @dima.teslenko88 and welcome to the community!
This is most likely something wrong with the file itself. Does the name of the file start with a number of does it have "bad" characters like . , ; etc in the file name?
Also, you'll want to check your plugins and make sure the TiffFloatReader plugin is enabled and/or you may need to disable it then re enable it to see a change.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
dima.teslenko88
Hi, Thanks for the reply Sean.
name file: liondm and also I checked tiffloatreader and it is load...
Actually, if I load this texture and connect to displacement slot in the geometry, it works and rendering fine... The error happens when I try to load this texture in a node which was created by paint tool.
I also tried to use this texture but with 16bit and I got success, but I can't connect this texture created in expressions shelf to displacement in primitives shelf.
Do I miss something?
Maybe anyone knows where I can find instruction step by step how to apply displacement to Xgen?
Thanks!
sean.heasley
Hi @dima.teslenko88
You could follow along with this:
dima.teslenko88
hmmm.... I thought, first of all, I need to create a color expression on the expression shelf and then start to paint, after, load the displacement texture into this node and then connect it to the displacement in primitives shelf...
but, I will try this method
Thanks a lot
sean.heasley
Hey @dima.teslenko88
Just wanted to check in to see how things were going. Did the method I provided help you at all?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
dima.teslenko88
Hey Sean,
No, that video is totally useless, but I found the correct way. I created a new 32bit Tiff Ptex displacement map via Modbox and when I created a new displacement map in Maya after that I just copied map from the Mudbox and pasted it into the folder with the displacement from Maya.
All the best
DT
sean.heasley
Hi @dima.teslenko88
Ah ok well I'm glad you figured it out! I went ahead and marked it as the solution for the thread.
