Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Xgen Archives without Mental Ray
6 REPLIES 6
MisterVal
721 Views, 6 Replies
MisterVal
I use Arnold as my default renderer, and I do not install Mental Ray on my system. When trying to export x-gen archives, I get the following error in my log:
AbcExport v1.0 using Alembic 1.5.4 (built May 8 2014 13:47:10)
Traceback (most recent call last):
File "C:/Program Files/Autodesk/Maya2016/plug-ins/xgen/scripts/xgenm/xmaya/xgmArchiveExportBatch.py", line 166, in <module>
sys.exit( main( len(sys.argv), sys.argv ) )
File "C:/Program Files/Autodesk/Maya2016/plug-ins/xgen/scripts/xgenm/xmaya/xgmArchiveExportBatch.py", line 153, in main
cmds.loadPlugin(p)
RuntimeError: Plug-in, "Mayatomr", was not found on MAYA_PLUG_IN_PATH.
Is there any way to export an xgen archive without installing Mental Ray?
cmds.loadPlugin(p)
6 REPLIES 6
3dMastermind
in reply to: MisterVal
3dMastermind
The issue seems rectified.
I tested in 2016 SP2 >Windows.
I turned off my "MayatoMR" in the plug-in manager prior to testing.
Thanks.
Manny Papamanos
StingRay | MotionBuilder | Maya | Mudbox
Games QA Specialist
Thanks.
Manny Papamanos
Games QA Specialist
ray
in reply to: 3dMastermind
ray
I have the same problem but I can't understand how to solve it. I don't have Mentalray installed and it seems Xgen doesn't export archives without it. Anyone can help ?
Thank you
Using Maya 2016 SP6 ext1 on Windows 7
Thank you
in reply to: ray
also turn off xgenmr plugin before it works again
ray
ray
Thank you
Thank you
in reply to: ray
perhaps you can help me then?
Unless i work from my default users projects dir, i can't get maya to save a PTEX file when making a ptex attr map in Xgen?
Michael_Todd
Michael_Todd
Add the path to the project to the File Data Path, it can be an absolute path or relative. You can have several ; seperated paths and xgen will look thruogh them in order till it finds what it needs. Files will be save to the first location it can resolve.
2015-10-08 14_06_14-Autodesk Maya Preview Release 59 - Not for Resale_ C__Users_toddm.ADS_Documents_.png
Michael Todd
XGen Product Owner and Designer
Michael Todd
