where has UV Rotate's yellow cirlce gone?
Amit_Karny_עמית_קרני
Hi there,
I cannot rotate my UV only via the UV toolkit bar right aside.
sean.heasley
Hi @Amit_Karny_עמית_קרני
You'll want to check to make sure your UVs aren't pinned. You can do this by going to UV Toolkit> Pinning > Unpin All.
If that doesn't work you may want to try deleting your settings/preferences.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Thank you
