Warning: 'Null' type not supported by COLLADA. Only the transform data of node:
I was given a T posed model. I rigged the skeleton, put it in position, froze the transformations, stuck a base underneath it, and now I want to export it as a .dae file. The model already has a texture on it, but the base is a white material I applied.
It doesn't export with the texture. What's the deal? I am super new to Maya but it seems like there are never any straight answers to any problems I run into on this thing I'm losing my mind a little bit!
I'm on Windows 10, latest version of Maya.
sean.heasley
Hi @Anonymous and welcome to the community!
What are you trying to export to?
Certain programs wont automatically apply a material to them on export.
Please come back with as much information as possible and I'll be happy to assist you further!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
sheldonkruger
Hey Sean,
I stumbled upon this post, because I am getting the same error
Would you be interested in reviving this topic, and possibly getting to the bottom issue with me?
Thanks you.
sean.heasley
Hi @sheldonkruger
Usually that kind of error happens when you have groups on any of your mesh or bones. Check your outliner and make sure you dont have any group. By default, maya will group objects after they have been separated to preserve transformations. Also, groups can appear on some joints after certain operations. In short, collada does not support groups so get rid of them.
It's also not a super important error anyway - it's a warning that there's information lost in the transition. So essentially: your model is the same, it's just the data that's behind it that's lost. However if you're noticing important information missing etc. let me know and we can try and work further with this.
sheldonkruger
Hey Sean,
Thank you so much for the response! It really helped. I've made really good strides in my collada troubleshooting over the last few days. Still lots of testing, so I'm going to bookmark this chat and reach out to you again, if thats alright.
Thank you once again!
-S
