Vray plugin can not be load
Vray plugin cannot be loaded,
// Error: file: //192.168.5.179/apps/shared/ddp/maya/2018.0.3/platform-windows/scripts/others/pluginWin.mel line 290: Unable to dynamically load : //192.168.5.179/apps/shared/ddp/vrayformaya/3.60.03/maya-2018/platform-windows/maya_vray/plug-ins/vrayformaya.mll
The specified module could not be found.
// Error: file: //192.168.5.179/apps/shared/ddp/maya/2018.0.3/platform-windows/scripts/others/pluginWin.mel line 290: The specified module could not be found.
 (vrayformaya) //
// Error: file: //192.168.5.179/apps/shared/ddp/maya/2018.0.3/platform-windows/scripts/others/pluginWin.mel line 290: ImportError: file \\192.168.5.179\apps\shared\ddp\vrayformaya\3.60.03\maya-2018\platform-windows\maya_vray\scripts\vray\plugin.py line 5: DLL load failed: The specified module could not be found. //
// Warning: file: //192.168.5.179/apps/shared/ddp/maya/2018.0.3/platform-windows/scripts/others/pluginWin.mel line 290: Failed to run file: //192.168.5.179/apps/shared/ddp/vrayformaya/3.60.03/maya-2018/platform-windows/maya_vray/plug-ins/xgenVRay.py //
// Error: file: //192.168.5.179/apps/shared/ddp/maya/2018.0.3/platform-windows/scripts/others/pluginWin.mel line 290:  (xgenVRay) //
I am pretty sure it is not vray's problem. Because my local install maya can load vray using the same configuration.
sean.heasley
Hi @Anonymous
Have you tried uninstalling and reinstalling Vray?
Have you tried deleting your settings/preferences then reloading the plugin?
Has Vray worked before on your setup or is this your first time installing it on your machine?
Hi:
I have already tried settings/ preferences but the error still . And the Vray is deployed following the official guide and it works for the older maya version. So I guess that it isn't Vray's problem.
sean.heasley
Hi @Anonymous
Hmm ok. It looks like you're on Update 3 of Maya 2018. By chance, can you update to our most recent Update 4 and see if this issue still occurs?
Let me know if anything changes!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
