My Maya 2020 viewport is having an issue.
I'm on Windows 10 Pro - Version 10.0.19042
I have 3 NVIDIA A5000 video cards running driver 462.31
Maya 2020.4
Maya seems to be the only software I run with any kind of display issue.
Thanks for any advice or help!
Solved by MikeVerta. Go to Solution.
SOLVED.
There was a system Environment Variable called QT_DEVICE_PIXEL_RATIO (set to "auto"). I don't know where this came from. Possibly a Fusion 360 install. I removed it and the application began behaving normally.
