Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
UVs are stuck in place
5 REPLIES 5
castanedakevin1424
381 Views, 5 Replies
My UV's are stuck. Just a moment ago they were fine I was able to move everything and its only after I sewed and connected some of the UVs that I couldn't move them. I've already tried Unpinning everything to see if that was the issue but I still can't rotate, scale, or move. Thank you for the help!
5 REPLIES 5
Select faces, edges, verts or Uvs to move with the move tool.
I've already tried moving them with the move tool int the UV editor tool bar and with the key. I also tried moving the verts but nothing. Also, do you happen to know why MAYA is continuously crashing on me? It's every time I UV edit. I'm wondering if its an issue with the plugins.
Try on a new scene, if problem persists reset preferences.
how's the general file history when you crash?
I imported the model onto a different scene and the crash stopped. I UV edited and it didn't crash. Though I have noticed in the past that Maya will crash when I'm applying a material after I've finished UV editing, not exactly sure why that is.
