My UV's are stuck. Just a moment ago they were fine I was able to move everything and its only after I sewed and connected some of the UVs that I couldn't move them. I've already tried Unpinning everything to see if that was the issue but I still can't rotate, scale, or move. Thank you for the help!
Solved by damaggio. Go to Solution.
