Uv map Seam issue
Uv map Seam issue
Message 1 of 25
Uv map Seam issue
I'm having a seam issue right in the middle of my symmetrical object.
I'm mirroring the uv's but i can't tell if the geometry of my object is the issue or my uv's.
After mirroring
With the normal map
It shows an awful seam
I also tested in marmoset toolbag and the seam still persists
Can I have some help here? thanks
Replies (24)
Message 21 of 25
damaggio
tiles not channels I meant....gotta go to gym now....later.
Message 22 of 25
damaggio
You can't ...not with sculpting involved....yes , if it is only a texture and bump object....I don't even know how Zbrush let you paint the mesh like that...didn't iy give you warnings?....about your Uvs?
Message 23 of 25
hmm it explains a lot !
i'm gonna try it ty so much 🙂
Message 24 of 25
So i took as solution what you said and it really helped 🙂 but i still have a less agressive seam there
I wonder if i can completely get rid of this seam..i tried methods like this one to paint the seam in photoshop
http://www.polycount.com/forum/showthread.php?t=51088
But i didn't get any different result.
Message 25 of 25
damaggio
Im sorry that the problem is stil there, I thought about a hack paint photoshop done on the Map like what is in the tutorial but I figured there wer better choices, If sewing the seem is not an option I really don't know what to else to say, it seems like there will be the problem of the inverted normal at the end of his tutorial...he points out that  one of the UV shells is inverted like I explained before....you must be aware of that.
