Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Urgent help...
2 REPLIES 2
sergiobentes
111 Views, 2 Replies
Urgent help...
Goodnight. I'm new to working with Maya and I have a question whose answer should be simple but I don't know how to solve it. I'm on a project where I used 34 lambert and 4 blinn materials. Now that I need to use 2 blinns on 2 surfaces, when I trigger "Assign Existing Materials", the list is big and the blinns are at the top of that list and no longer appear. Is there a way, for example, to choose inverted alphabetical order, or to split this list in two so that I can access the materials that are first, at the top? Or another solution? Thank you in advance for your help as it is important to me. Thank you very much.
2 REPLIES 2
Use the Hypershade to assign materials.
https://linktr.ee/cg_oglu
Solved! Thanks my friend! Thanks a lot!
Technology Administrators
