Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Update a string with procedure - Issue
4 REPLIES 4
t.pansiot
358 Views, 4 Replies
Here is my issue, I want to create a tool to change a string Value:
Theoric Example:   Variable called  "Name One"
Click on the tool to update Variable in "Name Two"
MEL Script:
string $Target = "NAME_ONE";
string $window = `window -title "Long Name"
-iconName "Short Name"
-widthHeight 200 55`;
columnLayout -adjustableColumn true;
button -label "Change Name" -command "NewName($Target)";
button -label "Close" -command ("deleteUI -window " + $window);
setParent ..;
showWindow $window;
proc NewName(string $Target){
$Target = "NAME_TWO";
print $Target;
print $Target;
During the procedure, it seems to work, nut as soon as I print $Target again, it remains, "Object_One"
Anyone would know a trick?
Labels (7)
4 REPLIES 4
mspeer
in reply to: t.pansiot
Hi!
Try something like this:
global proc string NewName(string $name){
$name = "NAME_TWO";
return $name;
NewName("whatever");
print `NewName("whatever")`;
print (NewName("whatever"));
t.pansiot
in reply to: mspeer
Here is the solutions: string should be "global string" and it should be called inside the proc like this:
global string $Target = "NAME_ONE";
button -label "Change Name" -command "NewName()";
setParent ..;
showWindow $window;
global proc NewName(){
global string $Target ;
print $Target;
print $Target;
t.pansiot
in reply to: mspeer
Thanks a lot Mspeer, I found a solution bellow
mspeer
Hi!
Yes I tested this too and it did not work, but I guess this was, because I had already declared the variable based on your example code and would have needed to close and reopen Maya.
Technology Administrators
