Here is my issue, I want to create a tool to change a string Value:
Theoric Example: Variable called "Name One"
Click on the tool to update Variable in "Name Two"
MEL Script:
string $Target = "NAME_ONE";
string $window = `window -title "Long Name"
-iconName "Short Name"
-widthHeight 200 55`;
columnLayout -adjustableColumn true;
button -label "Change Name" -command "NewName($Target)";
button -label "Close" -command ("deleteUI -window " + $window);
setParent ..;
showWindow $window;
proc NewName(string $Target){
$Target = "NAME_TWO";
print $Target;
print $Target;
During the procedure, it seems to work, nut as soon as I print $Target again, it remains, "Object_One"
Anyone would know a trick?
Solved by t.pansiot. Go to Solution.
Hi!
Try something like this:
global proc string NewName(string $name){
$name = "NAME_TWO";
return $name;
NewName("whatever");
print `NewName("whatever")`;
print (NewName("whatever"));
Here is the solutions: string should be "global string" and it should be called inside the proc like this:
global string $Target = "NAME_ONE";
button -label "Change Name" -command "NewName()";
setParent ..;
showWindow $window;
global proc NewName(){
global string $Target ;
print $Target;
print $Target;
Hi!
Yes I tested this too and it did not work, but I guess this was, because I had already declared the variable based on your example code and would have needed to close and reopen Maya.
