Hello!
I have a problem with the graph editor. I am using non weighted tangents and would expect the tangent handles to be same lenght on both sides and not stretch or shrink. They do however. See images attached. I am using maya 2017. That is what we use at work as well and there is no problem with the tangents there... Anyone know the setting to keep them all the same lenght? They don't behave like this in "classic", but I prefer to work with "modern" graph editor.
Best,
Mikael
Solved by sean.heasley. Go to Solution.
Hi @Anonymous
What GPU are you using and does the driver version match up with our certified hardware list?
You can find our certified hardware list here!
Also, is your Maya 2017 up to date? If not, please update Update 5 and let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
