Hello all, a noob here. I have made a polygon and rendered it and it is a thing of beauty, but the whole purpose for doing so is to be able to use it in Google Earth, and for that, I need to export it as a DAE file. However, all the Include Options are greyed out including "Include Texture Info" So all I get to export is a single .dae file, and no .mtl file and no texture file(s). It works ok with a pure FBX export, but Google Earth only accepts DAE files.
What am I missing out here?
I have included my Scene file and my texture as a PNG file below. I have used the TGA format in my scene, but you don't allow them to be uploaded. So you will have to convert it to TGA to use it. Also had to zip the MB file as it said the content does not match..
Solved by tony.su. Go to Solution.
Sorry. You can't export DAE with texture from Maya.
In Maya help:
Note: When you export in Collada format, textures are not embedded, even when the Embed Textures option is activated.
You can try export other format and then user other tool to get DAE with texture.
Thank you for the swift response Tony.
Is this something for the future? Should I put a request in?
Thank you kindly.
