Hi. I saw couple of posts that having the same problem. but mine is different.
Every time i create/load a scene , when i press F it goes blank and NaN.
I have no object and Even if I create a new scene and hit F it goes blank.
I know how to reset the camera, but I need F button. so how to fix this?
Thank you
have a nice day
I don't know what was the problem exactly but I found a solution.
Delete prefs completely and run maya again.It will fix it
If you don't want to delete your prefs, try setting your defaultFitFactor pref to 0.95.
https://forums.autodesk.com/t5/maya-forum/focus-is-not-working/td-p/7670571
optionVar -fv defaultFitFactor .95;
