Transfer hotkey scripts
viaframe
viaframe
Hello, since I use Maya 2022 also on my home office pc I have copied the prefs. Among them are also the files for the hotkeys:
userHotkeys.mel, userNamedCommands.mel and userRunTimeCommands.mel.
Unfortunately, when I open the hotkey editor on the other PC, the scripts do not show up under "Custom Scrips" and the corresponding hotkeys did not work. I get then the message Cannot find procedure...
I would be grateful for a tip
Cheers
Sebastian
nuckle
I just had this same issue and posted in hopes of a reply. I just ended up having to rebuild my hotkeys/custom scripts .  I saved everything and backed up the doc/maya folder. Custom scripts do not save apparently.
https://forums.autodesk.com/t5/maya-forum/hotkeys-and-custom-scripts/m-p/11019793/highlight/true#M92...
viaframe
Hi, i think i found out what the problem was. In my office i used maya 2022.3 and at home 2022.1. After updating at home to 2022.3 everything worked fine. Took me nearly a complete day to find out🙈
Cheers
