Tapping space bar won't change viewport
Message 1 of 12
 When I tap the space bar to go between the 4-view panel and then tap again to maximize a specific panel, it no longer does anything.
What have I unknowingly changed in the settings to make this happen?
Replies (11)
Message 2 of 12
Multiple thinks can effect the viewport behavior. The most efficent and simple way is to reset the Maya prefs.
StepByStep: https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
If you have many custom settings/scripts/hotkeys i don´t recommand it. Hope it helps! :3
Message 3 of 12
Thank you! That fixed it.
Message 4 of 12
This method did not work for me. Are there any other options to solve this issue?
Message 5 of 12
This did not solve the problem for me.
Message 6 of 12
Hi, I figured out an easy way to fix my issue. If you have a small panel that still opens drag that up to view its options. Then on the new panel use Panels> Layouts > Four Panes
Message 7 of 12
this helped alot, thankyou
Message 8 of 12
Thank you this helped
Message 9 of 12
gaboreturi
This sorted out well. Once I did this it is automatically working with Space bar after. Thanks
Message 10 of 12
rd2025
Community Visitor
Community Visitor
Perfect, fixed the problem
Message 11 of 12
stephen_scubelek
Community Visitor
Community Visitor
Going to Windows > Settings/Preferences > Panel Editor and then under Layout selecting "Four View" and that will force it to go into that panel layout. You can then conveniently add that button to your shelf using the "Add to Shelf" button.
Message 12 of 12
stephen_scubelek
Community Visitor
Community Visitor
Resetting preferences is not a solution.
