Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Substance Painter for Maya 2019 textures show up pink or magenta.
7 REPLIES 7
Message 1 of 8
3302 Views, 7 Replies
Hi. I recently downloaded Maya 2019 along with the latest Substance plugin from Allegorithmics web site and everything seemed to have installed correctly. Problem is when I create a Substance texture node and apply it the mesh the mesh turns black in the perspective view (all views) and Arnold renders it pink or magenta color. I followed the steps that Autodesk recommends for updating shaders and turning certain things on and off but I still can not see the texture. Can anyone help please?
7 REPLIES 7
Message 2 of 8
sean.heasley
Hi @Anonymous
The pink is happening because you aren't using an Arnold shader you are using a Stingray PBS shader.
If you use and Arnold shader like aiStandardSurface you should be able to see the render.
Message 3 of 8
in reply to: sean.heasley
Thank you Sean. That was my issue. But, now all of the Substance textures do not have a base color plug for me to plug them in to my ai shader.
Message 4 of 8
mspeer
Hi!
You can connect any Color Output to any Color Input,
so connect "Out Color" to ...Color (like "Base Color" or "Specular Color") at aiStandardSurface.
Message 5 of 8
in reply to: mspeer
Thank you but nothing works. I don't think it's me either. I have followed the tutorial from substance exactly and I can't get any substance textures to either plugin correctly or work.
Message 6 of 8
mspeer
Hi!
Here is a detailed explanation how to set it up correct:
https://support.allegorithmic.com/documentation/integrations/arnold-5-for-maya-157352171.html
Message 7 of 8
sean.heasley
in reply to: mspeer
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did the link that @mspeer  provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 8 of 8
in reply to: mspeer
Thank you.
@mspeer wrote:
Hi!
