Square artifacts on turtle render for baking id-map
Hello
When i'm using turtle to bake id-map, i've got square artefacts on it.
This artefact appears on the end of the render, not during it.
any idea ?
sean.heasley
Hi @Anonymous and welcome to the community!
I'd need to see the scene/model to get a better idea on why this may be happening.
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Let me know if anything changes!
Hello
I put the scene on gdrive :
https://drive.google.com/file/d/18-DumtRKmt_Ehw5dUScxdyWm7xfB_AY8/view?usp=sharing
Thanks for your expertise
sean.heasley
Hi @Anonymous
Thanks for attaching the scene file!
This is most likely happening due to your models topology and not having a high poly model to bake from.
This video gives a pretty good summary of the bake process for ID maps and I highly recommend you check it out!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
I'im already knows this video.
It's working but, the borders of the shape having color pixels (like in the video tutorial).
So i finally made the color id map using substance painter, it's working fine
Thanks for your help.
