Sketchfab Plugin Bug
daoacclt
daoacclt
I am having a very annoying sketchfab export plugin bug.
Whenever I try to upload my scene after some loading it says "try polling processing status (attempt #0) ... "
sean.heasley
Hi @daoacclt and welcome to the community!
Can you try unloading and reloading the plugin?
How large is the scene file you're trying to upload?
Also is the plugin up to date?
sean.heasley
Hi @daoacclt
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
daoacclt
I have posted this same forum thread in the sketchfab forums, since posting these 2 threads I have resolved the issue though the bug can still be recreated.
The bug is seemingly caused by adding a diffuse map as a color on your material, its perfectly fine most of the time, but suddenly you add one more and this bug appears. On one instance removing that material and replacing it with a fresh lambert fixed it, on another case I had to remove every single material that had a diffuse map and replace them with just basic grey lamberts for the bug to go away.
The most frustrating part is that if you google this bug you find a couple of threads like mine, but none of them ever get solved, nor do the people respond and say that it was fixed.
