So Maya lets you have window/editor sensitive hotkeys. You can set up a key to do different things depending if you are in the model panel or graph editor for example. It's a really helpful feature if you use lots of hotkeys.
Has anyone ever tried to make editor sensitive marking menus though? A different marking menu would pop up depending on which window you're in, by pressing the same hotkey the marking menu is assigned to.
I can't seem to get it to work with Maya's hotkey editor. I'm probably going to have to code this functionality myself. I was curious if there's a more simple process first though.
