Announcements
AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Shortcuts for going in Vertex, Edge, Face and Object mode?
bobopet
bobopet
I got my new Wacom Intuos Pro M and I want to assign those 4 modes (Vertex, edge, face and object mode) to my tablet keys so i can easily cycle through them. In the wacom properties app, I assign a "keystroke" to a certain button and I should type in the shortcut (from maya in this case) and give it a name of preference. Then, when I open up maya if I click it it will execute the shortcut just by a single click so i don't have to hold multiple keys on my keyboard everytime I want to do it. So, are there any shortcuts to switch between Vertex, Edge, Face or Object mode?
Thank you in advance
sean.heasley
Hi @bobopet
Yes there are! These can also be changed to whatever keys you'd like but by default they are:
F8
Select > Object/Component (Switch between object and component editing)
F9
Select > Vertex
F10
Select > Edge
F11
Select > Face
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
bobopet
Thank you so much.
