# Error: RuntimeError: Error occurred during execution of MEL script
Invalid redeclaration of variable "$tmp" as a different type. #
what to do ?
i can not open shelf editor
Hi @Anonymous
Do you have any custom scripts/plugins installed that may be causing this?
A quick test you can try is deleting your settings/preferences.
Please let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
