Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Shape Editor not showing bottons below "Key" and "the Eye mark"
3 REPLIES 3
sui_orangeblade
264 Views, 3 Replies
Hi, I'm having problem with the Shape Editor in MAYA 2023.
The Shape Editor does not show circle bottons below the "Key" and the "Eye".
Setting Keys and Solo/Unsolo still works with right click mouse.
Does anyone know how to deal with this?
※ I've reset preferences, but in made no changes
3 REPLIES 3
Hi @sui_orangeblade ,
Thanks for bringing your issue to the Maya forums! Interesting that the issue isn't resolved with a UI reset. I found a similar thread that might offer an alternative solution here
  • What happens if you Key the blendshape by hand?
  • Is this the same on all objects or does the shape editor not display on specific objects?
  • are you running any plugins?
Warm regards, and talk soon!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
@hagen.deloss
Hi,thanks for your reply
The blendshape works fine if I Key by hand, and the bottons does not show up in any objects.
I'm not running any plugins too.
In the end, I installed the latest version of MAYA 2023,and then the bottons appeared : )
@sui_orangeblade
Good to hear you found a resolution to the issue by installing the most recent update! There must have been something going on with UI resolution, an errant shelf or something 🤔
Hagen Deloss
