Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Animated Sweep Mesh Flippin
1 REPLY 1
mmmMUD69
80 Views, 1 Reply
Hello, I am animating an animated sweep mesh.
I created the sweep mesh based on an offset curve, using this well known method.
Animating works perfectly fine when I only key the max offset value, but when the min value gets animated as well,
there seems to be confusion of normals.
Perhaps there is a way to stabilize these kind of setup?
thanks
Martin
1 REPLY 1
MannaTheBerserk
in reply to: mmmMUD69
Did you check the curve direction before applying the sweep?
Also, have you rebuilt the curve to set its UV range from 0 to 1, rather than the default 0 to number of spans, and to make the CVs distribution more even?
