Sculpting Tool - Edges breaking when using sculpting tool in maya 2022
Step 1: Created the face
Step 2: Created Eye Socket and attached to the face using Append to polygon
Step 3: Made the selected object live
Step 4: Selected the Sculpture tool "Lift a Surface"  by pressing Shift key  When i tried to smooth the face
Expected: It should  smooth the face surface
Actual: The Faces are breaking
For better understanding added before, after image . please find the attached .
Christoph_Schaedl
Are you sure thise edges are welded?
Try to select one vertex and move them with the move tool.
https://linktr.ee/cg_oglu
@Christoph_Schaedl Thank you for the response.  Yes the edges are welded. i tried moving the vertex it is merged. but still facing the issue.
Christoph_Schaedl
Please zip the maya file and upload it here i take a look.
Sure. Have uploaded the zip file.
Christoph_Schaedl
There are faces ontop of faces and inverted geo.
Delete the whole area and make it new is the fastest way to fix it.
Thank you. will fix it .
