Scripts will not open
sndye
sndye
Hello, I have been having some trouble opening up some scripts in maya. I have opened up scripts before, but these two are being stubborn.
sean.heasley
Hi @sndye
I just tried this on 2018.3 and had no issues.
After pasting the mel files in the scripts folder did you open the Script Editor and run the commands?
The commands are: oaExportSDK; and scriptomatic;
Please let me know if anything changes!
sndye
All right, so I was just doing it wrong. How did you find out the command code? Did I miss it?
Also, the scriptomatic (rigomatic) one is giving me an error code telling me:
// Error: line 1: Cannot find procedure "scriptomatic".
sean.heasley
Hi @sndye
Oh sorry its not scriptomatic its rigomatic; Smiley Tongue
As for how I found the code, there was a txt file in the folder labeled Help (this is usually the case with most scripts) and in that txt file they had a Directions section that mentions using that code to run the script.
Please let me know if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
