Announcements
Scene Loading Bug
Scene Loading Bug
Message 1 of 9
Scene Loading Bug
Hey everyone I'm having issues loading scenes that I've worked on in Maya.
I'll save something like this:
scene as savedscene as saved
Then later when I try to load the file it will open like this:
bugged load?bugged load?
After closing and reloading the file several times it will eventually load properly, but it's annoying and worrying. Earlier when I was trying to develop resources for a game using Unity engine, files imported to Unity would be messed up like this. So I don't want whatever the bug is propagating like that.
Is there anything I can do to fix this?
Replies (8)
Message 2 of 9
mspeer
Hi!
Check for animation on vertices.
For further help please upload the scene-file.
Message 3 of 9
Hey thanks for the tip! Could that by caused by my constantly accidentally clicking on the timeline?
Message 4 of 9
mspeer
Hi!
Unlikely.
Message 5 of 9
Ok well, I was trying to look up vertex animation to figure out how to check for animation on vertices and I haven't found exactly how to do that yet. So, how would I go about it?
Also, if I couldn't accidently apply it by creating empty keyframes then it's probably not the issue because aside from that I have done no animation at all. All I've done so far is the model as you see it when it loads properly, so are there any other potential causes?
Message 6 of 9
mspeer
Hi!
Again: For further help please upload the scene-file.
Message 7 of 9
Ok, the scene file is attached, thanks again for your help!
Message 8 of 9
mspeer
Hi!
That's funny i was able to get 3 different versions when opening the scene again and again.
The solution:
If you open the scene and the object is displayed correct, select it and then:
Edit -> Delete By Type -> History
You should delete history more often.
Message 9 of 9
Thank you! I'll remember to do that from now on...
