Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
RenderGlobalsWindow Maya 2016 on Windows 7
3 REPLIES 3
pixelmolkerei
371 Views, 3 Replies
Hi
Has anyone else ever had the problem (please see attached screenshot)
I did reset the maya emv, the wole maya settings and as well
deleteUI unifiedRenderGlobalsWindow;
buildNewSceneUI;
Any idea how to fix that (import in a new scene would work but it is not really a solution)?
Thanks for any help.
3 REPLIES 3
slimboJoe
in reply to: pixelmolkerei
Yes!  From what I can recall, it was a custom UI script or something like that.  A UI element call was made without a proper parent and it somehow was messing up the render window.  Try having the render window open to that tab BEFORE loading the scene or using a custom script with UI elements in it.
pixelmolkerei
in reply to: slimboJoe
Thank you for the tip. But unfortunatly still no progress.
These small things Smiley Frustrated
tony.su
It's strange. If you reset Maya to Default, it shouldn't be.
Could you try to reset again?
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Tony Su
Product Support
