Hi
Has anyone else ever had the problem (please see attached screenshot)
I did reset the maya emv, the wole maya settings and as well
deleteUI unifiedRenderGlobalsWindow;
buildNewSceneUI;
Any idea how to fix that (import in a new scene would work but it is not really a solution)?
Thanks for any help.
Yes! From what I can recall, it was a custom UI script or something like that. A UI element call was made without a proper parent and it somehow was messing up the render window. Try having the render window open to that tab BEFORE loading the scene or using a custom script with UI elements in it.
It's strange. If you reset Maya to Default, it shouldn't be.
Could you try to reset again?
