I can't launch the maya software in my lap , It alshows shows VCOMP140.dll is missing error.How can i fix this error
MAYA version :2019
os:Windows 10
Solved by sean.heasley. Go to Solution.
Hi @Anonymous and welcome to the community!
This is probably due to some corruption with your C++ libraries.
Thankfully we have an article with steps on how to solve this!
From that article:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
