Problem with move rotate and scale tools
Good evening!
I am working with Windows 8 on a PC. In Maya, i can use and click every tool. But if I want to move, rotate or scale a 3D-Object, it doesn't anything. I can select a cube, but if i try to move, it doesn't select the move-arrows. It's like there wouldn't be a move-arrow.
Didn't find the same problem.
Best regards
sean.heasley
Hi @Anonymous
A quick test you can try is deleting your settings/preferences.
If that doesn't help you may want to check your GPU driver and make sure the driver version is the same as our certified hardware list.
You can find our certified hardware list here!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
