Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
problem opening hypershade in Maya 2019
4 REPLIES 4
718 Views, 4 Replies
Hi Guys! I have a problem with opening Hypershade in Maya2019, when I open Hypershade, Maya freezes and it takes about 3 to 5 minuts to load the Hypershade window, I'll appreciate your help.   thanks
4 REPLIES 4
creationasif
Hi @Anonymous
where are you facing this issue ? in a particular file or in a blank maya ?
I would suggest checking your Graphics Drivers and updating those to see if that fixes the issues.  Also what graphics card do you have? do you have enough free space in your C drive ?
Let me know if that helps you out.
in reply to: creationasif
yes even in a blank project and my graphic card is rtx2020 , windows 10 .
it was not used to be like this before, like one month ago.
jordan.giboney
Hi @Anonymous
Thanks for posting! In addition to @creationasif 's suggestions, I would also recommend the following:
Let us know if you have found a solution other than these suggestions 🙂 We would love to hear about it.
Thanks for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
in reply to: jordan.giboney
I renamed the prefs folder to (old_prefs) and it solved my problem.
documents >maya>version >rename prefs folder to what ever you want, or delete it> then after restarting, Maya itself creates a new prefs folder.
you can copy your own shelfs or any other preferences into the new one.
