image sequence stops working after a certain amount of frames
Message 1 of 1
I'm trying to render 230 frames but my aigobo filter stops working after 89 frames. I don't know how to fix it. I'm using an image sequence as slidemap. Weirdly enough, it stops  working after 89 frames which is exactly the amount of frames in the original image sequence. It also starts working again at 100. I tried adding more frames to the image sequence, extending it to over 300 frames. I reloaded the image in file attributes, but I'm missing the 10 frames in between.
This is frame 90
and this frame 100
I've tried reloading the image sequence at frame 90 but it's still not working. It also doesn't show anything in the sample box in frames 90-99.
Replies (0)
