Primary Visibility won't work on XGEN
mhamid3d
mhamid3d
Using Arnold 4, first I tried setting primary visibility to off on the shape node of the description, but it still renders. Then I tried creating a Set with the description shape and setting a primary visibility override and it still renders out fully. Is there anything I'm missing??
mspeer
Hi!
Use the description node (in Outliner directly below collection)
mhamid3d
Thanks but that didn't work either.
Michael_Todd
You have to select the shape node:
XGen Primary Visibility
cheers
Michael Todd
XGen Product Owner and Designer
sean.heasley
Hi @mhamid3d
I'm just checking in to see if you need more help with arnold picking up xgen. Did the suggestion to use XGen Primary Visibility that @Michael_Todd provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
mhamid3d
It ended up being an issue with Arnold. I updated Arnold to a newer version and it worked. Thanks everyone!
