Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Preview not playing smoothly?
8 REPLIES 8
Message 1 of 9
714 Views, 8 Replies
i have done a matchmoving work in syntheyes and brought it to maya. all was ok. And when i rendered out the passes i found out that the objects is somewhat moving. I couldn't check the playblast everytime. Even though its in real time. i cannot seem to preview the sequence smoothly. can anyone please tell me whats the problem?
8 REPLIES 8
Message 2 of 9
J450NP13
Are you saying your tracking isn't good or there's an issue with the camera??
Message 3 of 9
in reply to: J450NP13
No everything is fine but when I hit play everything becomes glitchy. There
is no main problem with the trackers or anything it is just that I cannot
see the RAM preview smoothly there is always a glitch in it. I have to play
boost everyone to see the final shot.
Message 4 of 9
J450NP13
Where are you hitting play? in AE?
Message 5 of 9
No in Maya. This is Maya forum and why would I talk about AE in here. It's
okay if you can't seem to find what am I trying to say let alone the
solution of it.
Message 6 of 9
J450NP13
Maya doesn't have a RAM preview...it's a playblast....
If your scene is large...you won't get a smooth playback unless you have a high-end machine.  Or use a small resolution.
Message 7 of 9
Ok yes playbalast, I forgot the name. I have core i5 650 3.2ghz with 8 GB
ram and gtx 960 2 GB Nvidia card. Doesn’t it come in high end machines if
not what's obsolete?
Message 8 of 9
J450NP13
That seems like a low to middle end machine.  But depending on your scene complexity you should still get a smooth playback.
It depends on your scene.  Or you have a bottleneck somewhere.
Message 9 of 9
Anifex09
It sounds like a frame rate issue.  Does your matchmove's frame rate match maya's frame rate.  What playblast file type are you using (H264 - AVI or image seq) ???
