i have done a matchmoving work in syntheyes and brought it to maya. all was ok. And when i rendered out the passes i found out that the objects is somewhat moving. I couldn't check the playblast everytime. Even though its in real time. i cannot seem to preview the sequence smoothly. can anyone please tell me whats the problem?
Maya doesn't have a RAM preview...it's a playblast....
If your scene is large...you won't get a smooth playback unless you have a high-end machine. Or use a small resolution.
That seems like a low to middle end machine. But depending on your scene complexity you should still get a smooth playback.
It depends on your scene. Or you have a bottleneck somewhere.
It sounds like a frame rate issue. Does your matchmove's frame rate match maya's frame rate. What playblast file type are you using (H264 - AVI or image seq) ???
