Hi guys!
I'm super new to Maya and I'm loving it.
I have a question: is it possible to have one object with multiple separate meshes (like on the attached image), and to 'layout' one mesh per UV tile without having to manually move the UV? Like I can just click "Layout" and it'll automatically center the UV of the selected mesh on the tile that I want?
Thanks!
Solved by mspeer. Go to Solution.
Hi!
In Layout Setting just enter the amount of UV Tiles you wan to use and the UV shells will be distributed to individual tiles.
You can also use the Transform node to move individual shells to other tiles with just a few clicks.
