Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
PC Freezes - selecting CV on curve
0 REPLIES 0
Message 1 of 1
408 Views, 0 Replies
as of late ive tried modeling a knot. using EP curve. after doing so i go into Control Vertex selection and as soon as i select one of the points. the screen freezes with the only solution is to restart the PC. i have tried doing this in a new scene and still it happens which leads me belive that this issue is caused by maya.
currently im using maya 2015 SP5 Student Version, the following is my script editor's history on start up.
Loading GoZ support...done!
file -f -new;
// Warning: file: D:/Autodesk/Maya2015/scripts/startup/rememberViewportSettings.mel line 43: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
// AbcExport v1.0 using Alembic 1.5.4 (built May  8 2014 13:47:10)
// AbcImport v1.0 using Alembic 1.5.4 (built May  8 2014 13:47:10)
// Error: file: D:/Autodesk/Maya2015/scripts/startup/shelf.mel line 81: Object 'Curves' not found. //
// Error: file: D:/Autodesk/Maya2015/scripts/startup/shelf.mel line 81: Object 'General' not found. //
updateRendererUI;
createModelPanelMenu modelPanel1;
createModelPanelMenu modelPanel2;
createModelPanelMenu modelPanel3;
createModelPanelMenu modelPanel4;
buildPanelPopupMenu scriptEditorPanel1;
evalDeferred "showWindow scriptEditorPanel1Window;";
showWindow scriptEditorPanel1Window;Thanks for any Help in advance
 Thanks in Advance
0 REPLIES 0
