Only last object created exists in my scene when i open up my file?
prockoe
prockoe
So im having this crazy and frustrating situation happening to me.  I can model fine in maya...  but when i open up a saved scene it will only show me the last object i created.  I can see the objects in my outliner but they do not exist in any viewport and I cannot access them.  If i select them in outliner I get pivot handles but nothing else.  Any point in the right direction would be extremely appreciated!!!
I have also tried maya 2019 and 2020...  having the same issues.  I have just gone through uninstalling and reinstalling and updating my graphics card.  nvidia p5000.
Thanks for listening.
mspeer
Hi!
When you create a polygon cube and then a sphere and you save the scene and reload it, then only the sphere is in the scene?
Please provide a scene-file.
prockoe
Yup...  only the last polygon seems to exist.
ive attached a scene file..  i created a cylinder then a sphere saved it...  open back up only the sphere exists in viewport or can be selected.
also get this in the other window.  - thanks for any help!
Initialized VP2.0 renderer {
Version : 2016.11.53.12. Feature Level 5.
Adapter : Quadro M5000/PCIe/SSE2
Vendor ID: 4318. Device ID : 5104
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 8192 MB.
CPU Memory Limit: 15490.8 MB.
MultiDraw consolidation: enabled
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 11.2.162.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_khr_gl_event cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_nv_kernel_attribute cl_khr_device_uuid
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device Quadro M5000. Device Type: GPU Device is available.
00:00:00 673MB WARNING | [mtoa] [<built-in>] [node aov_write_vector] Assigning temporary node id 1138176 to associated Maya type name aiAovWriteVector.
mspeer
Hi!
Sorry, but there is no file attached.
prockoe
try to send a file again?
prockoe
i tried it on another computer and it seems to be working? so not really sure what the problem on my main cpu is???  what would be the main culprit of not displaying previous geometry?
mspeer
Hi!
The file is OK.
It seems you are using some settings on your computer that prevents you from seeing the objects.
Try a reset of your Maya Preferences.
Rename the folder prefs in folder 2020 to something like prefs_backup, or the folder 2020 to 2020_backup
(Don't copy preferences from previous Maya versions)
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
For further help, please provide some screenshots or a screencast.
