on Maya 2027 mtoa 5.6.1.2 load errors - cant find xgen dylibs and also has libAdskSeExpr.dylib clashing with the same library in Lib/App Support/Autodesk.
mattgidney
mattgidney
00:00:00 754MB WARNING | unable to load dynamic library: dlopen(/Applications/Autodesk/Arnold/mtoa/2027/procedurals/xgenSpline_procedural.dylib, 0x0005): Library not loaded: @rpath/libAdskSeExpr.dylib
Referenced from: <5593D3CF-6AD4-3C9F-A3FB-3CF1906511BB> /Applications/Autodesk/Arnold/mtoa/2027/procedurals/xgenSpline_procedural.dylib
Reason: tried: '/Applications/Autodesk/maya2027/Maya.app/Contents/MacOS/./libAdskSeExpr.dylib' (no such file), '/Applications/Autodesk/Arnold/mtoa/2027/bin/./libAdskSeExpr.dylib' (no such file), '/Applications/Autodesk/maya2027/Maya.app/Contents/MacOS/libAdskSeExpr.dylib' (no such file), '/Applications/Autodesk/maya2027/Maya.app/Contents/Frameworks/libAdskSeExpr.dylib' (no such file)
00:00:00 754MB WARNING | unable to load dynamic library: dlopen(/Applications/Autodesk/Arnold/mtoa/2027/procedurals/xgen_procedural.dylib, 0x0005): Library not loaded: @rpath/libAdskSeExpr.dylib
Referenced from: <0E30A83B-EABE-38F0-8642-5AFEBDB6779B> /Applications/Autodesk/Arnold/mtoa/2027/procedurals/xgen_procedural.dylib
Radwan-Almsora
This is a known macOS environment issue related to conflicting dynamic libraries (libAdskSeExpr.dylib) loaded by Maya and Arnold, coupled with macOS's strict @rpath dependency linking.The CulpritArnold’s XGen procedurals are attempting to load libAdskSeExpr.dylib. However, because it's listed in a local path /Applications/Autodesk/maya2027/Maya.app/Contents/Frameworks/, macOS's dyld search order picks up older or clashing versions in your system's Application Support folder or Maya's path instead of the correct Arnold/Maya framework location.
