Announcements
Objects not displaying in Viewport
nslewis9WKDL
nslewis9WKDL
I am a newbie but oversaw a series of animations that used an early version of Maya, with two scenes needing slight reworking.  I found backup CD's with the .mb files for those scenes along with everything else associated with the project, all in clearly labeled folders.  When I tried to open the .mb scene however, I just see a blank green screen in the viewport.  The names of the correct objects in the scene do show up in a list view, and the attributes pane shows values for the objects that seem right, but I can't see the objects themselves and nothing happens when I slew the timeline.  I put the scene file into the documents/Maya/default/scenes folder (am on an M1 Mac) where I think it should be.    That backup CD also has a movie file from the rendering and that is how I determined that this is the correct scene file.  I believe that the project originally was done on a PC and I am now loading it onto my Mac so perhaps there is a file path issue from objects that were referenced but not in the scene file, and if so then do I find the object files and put them somewhere and then specify the new/correct file path, or what?  I could send along the .mb file itself of course if that is helpful to get me over this hurdle.
damaggio
Yes, the file would be very helpful.
nslewis9WKDL
file won't attach; keep getting error message on the post saying "file type does not match its extension" but it is an .mb file and 8.3 MB in size.
nslewis9WKDL
converted in Maya from .mb to .ma and file is attached
