Object copy-paste between different Maya scenes in Maya 2025 does not work (it works in Maya 2024, 2023, 2022...)
artofillusionist
Message 1 of 9
artofillusionist
Many times I open more Maya windows together and open different scenes. I used ctrl+c and ctrl+v to fast copy-paste meshes between Maya scenes, between different Maya windows
What happened? Is this a "what new in Maya 2025" feature?
This worked even between different Maya versions like copy object from Maya 2022 to Maya 2023:
If I try copy paste between Maya 2025 scenes, nothing happen. If I try copy paste from Maya 2025 to Maya 2024 windows then I got this error
I checked this script is also in the Maya 2025 folder, why it is not working?
Replies (8)
Message 2 of 9
brentmc
We did some tests and on our end copy/paste has never supported going from a newer version of Maya to an older one.
FYI: We tested all the back back to Maya 2022 and the result was the same - works when going from older to newer version but not the other way around.
If you are feeling adventurous you could modify cutCopyPaste.mel in your Maya installation to add the -ignoreVersion flag to the file -import command in that script. Of course, this may not work if you are using features not available in the older version.
Thanks.
Brent McPherson
Principle Software Developer
Message 3 of 9
artofillusionist
My problem is not the old versions, but that ctrl+c and ctrl+v copy paste does not work for me between Maya 2025 and an another Maya 2025, however when I use the paste command from the menu, then it is working. Maybe a shortcut issue?
Message 4 of 9
nelsoncruz
Could indeed be another problem. When using 2025.1 to copy paste to another 2025.1 session, everything is working on my end. Have you tried with a set of fresh preferences to possibly eliminate an issue there?  I do not suggest deleting the folder but instead rename the 2025 folder in C:\Users\USERNAME\Documents\maya.  start Maya and see if the issue continues.
Nelson Cruz
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 5 of 9
artofillusionist
I reseted my Maya settings by deleting the maya folder from the documents, still copy paste (with ctrl+v) does not work for me between Maya 2025 to an another Maya 2025, just only with the "paste" command from the menu. Though I am using Maya 2025 and not 2025.1.
Message 6 of 9
nelsoncruz
Can you verify if the lookdevX plugin is loaded.  If so, can you try unloading and re-test your copy/paste workflow?
unloadPlugin LookdevXMaya.mll;
Nelson Cruz
Message 7 of 9
artofillusionist
Yes, the lookdevX plugin is loaded
I tried copy paste in the pc of other artist in the company, and it is same, copy paste shortcut does not work.
Message 8 of 9
mamay_euaa
Community Visitor
Community Visitor
I have the same problem with 2024 and 2025 Did you find any solution yet? I was able to copy it but when paste nothing happen not even an error code line
Message 9 of 9
art13eck
OMG LOL. lookdevX disable fix for me. I wanted to go back to maya 2023 because of copy paste problems. I had Crtl + V not working if nothing is selected in the scene. And Ctrl + C/V didn't work on selected object components.
