Hi, I have a problem, I can't see objects which are under the grid in side views also I don't see manipulators of the objects. It happens only when object is below the grid. In show panel nothing is hidden.
Solved by mspeer. Go to Solution.
Hi!
Very likely the value for Far Clip Plane on your camera is too low, cause even the grid itself is not visible, so increase the value for Far Clip Plane or move the camera and change the value for Translate Y.
