Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Not able to import .stl files
9 REPLIES 9
Message 1 of 10
Parmenides
22462 Views, 9 Replies
Parmenides
I am trying to import a .stl file. I get an error "Unrecognized filetype".   In the documentation it says that it should be available under the plugins but it is not there to turn on.  I am using Mac Maya 2018. Thanks.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Cus...
9 REPLIES 9
Message 2 of 10
sean.heasley
in reply to: Parmenides
sean.heasley
Hi @Parmenides
We have an article on this that may help you out.
Easy first step is to try deleting your settings/preferences. If that doesn't work you'll want to check to see if you can open the file in another program to make sure there's nothing wrong with the file itself.
Please let me know if anything changes!
Hi @Parmenides
Message 3 of 10
Parmenides
in reply to: sean.heasley
Parmenides
Sean, thanks for your suggestion of deleting the prefs. Yes, I have done that. I wouldn't post anything without doing that first as it is the default remedy.
That article would be a lot more helpful if they said, here is a simple STL file. Does this import for you?  Instead of "Doesn't work? Then its probably damaged".   I don't even know if the STL import is working correctly. Is it showing in your plugins?  If it is missing in mine, would the preferences affect that? Perhaps it was missed in this build?
Included is a cube in STL format. Can anyone on a Mac/Maya 2018 import this?
Message 4 of 10
sean.heasley
sean.heasley
Hi @Parmenides
Thanks for attaching the file! I had no problem importing it into my Maya 2018.4.
There is no longer a specific stl plug-in since 2018. There is the ATF plug-in which I recommend having loaded if it is not loaded already.
It's also possible this may be an issue on Mac specifically. What OS version are you using and is your Maya 2018 on update 4?
Hi @Parmenides
Message 5 of 10
Parmenides
Parmenides
I figured it out. The STL file that I was trying to import crashed Maya every time. Even though I scrapped the prefs, the next time I tried to import the STL to see if that helped, it must have destroyed the prefs again. Deleting the prefs used to be a couple times a month, now it is easily a couple of times a week.
Message 6 of 10
Hello!
i have the same problem..
Smiley Sad
i'm using maya 2018 ( win ) .. and in the list of the files to import ( under "import" ) cannot see "stl". ( i have all the others)
do i have to enable the option " import .stl" somewhere?
I've already looked in plug-in manager and in preferences.. i can't see naothing abouto stl files..
help!
thank you!
Anna
Hello!
Smiley Sad
help!
thank you!
Anna
Message 7 of 10
mspeer
mspeer
Hi!
It's all covered by ATF now, it should be available as "STL_ATF".
Hi!
Message 8 of 10
in reply to: mspeer
THANK YOU!!
i had to enable  the plugin , now  it works !
Smiley LOL
THANK YOU!!
Smiley LOL
Message 9 of 10
steventwigg2012
To make this less confusing for other novices like me who had to go searching, here was the proper solution:
Go to Windows>Settings/Preferences>Plug-In Manager
From there, search "STL" in the bar at the top, and where it says stlTranslator.bundle, check "Loaded" and "Auto-Load".
Cheers
Cheers
Message 10 of 10
in reply to: steventwigg2012
Bless you for guiding us on the right path!!
