While I am moving some vertices on poly mesh, the normals seem to be modified as am I doing this, then when I exit and enter object mode the normals seem to be fine. But this constant switching between the normals look is very distracting specially when working on low poly assets.
https://masterhotmail.tinytake.com/msc/ODAyOTMyNF8yMTE3MzUyMQ
You can clearly see in the video below that when I exit vertex mode and enter the object mode the normals look suddenly change (the real look of the normals is in the object mode):
https://masterhotmail.tinytake.com/msc/ODAyOTMzOF8yMTE3MzUzNQ
I also found this on reddit:
https://www.reddit.com/r/Maya/comments/uo4ie0/normal_shading_and_isolate_selection_issues_in/
