I succedeed to install Maya 2017 under Linux Mint Mate 2017 but I have still 2 errors :
First the color management error is still present, although I have make :
echo "LC_ALL=C" >> ~/maya/2017/Maya.env chmod 777 ~/maya/2017/Maya.env
And when I try to call sur contectuel menu with the Right clic Button I have this error :
Thany you for your hlep !
Bye
Vincent
Hi @Anonymous and welcome to the community!
We don't officially support Linux Mint Mate so it's always possible you will encounter errors like this.
For the color management error, we actually have an article on that here!
The solution steps are:
To avoid this error, please try the following workarounds:
Your second issue looks like something with Xgen so I would recommend making sure your GPU drivers are up to date and you'll also want to unload and reload your Xgen plug-ins which can be found under Windows->Settings/Prefs->Plug-in Manager.
Steps to update your drivers can be found here!
Please let me know if this helps at all or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
