near and far clip plane problem
Message 1 of 13
Hello
i have problem with black color on my object because of near and far clip plane
i tryed alot of number but the problem is not solved
Is there an option to resolve this problem automatically like  3ds max with out put the numbers for near and far clip plane 1.jpg
Replies (12)
Message 2 of 13
damaggio
If your far clipping plane is large as you have  you should increase the near...try 10.0
Message 3 of 13
damaggio
and that's for all your cameras.
Message 4 of 13
damaggio
and make sure is not a reversed normals issue if you see black geometry.
Message 5 of 13
thank u for your answer but
This solution does not work and there is no problem with reversed normals
i doI do not know why this problem occurs with me always When I work on Maya But with the 3d Max There is no such problem
By the way my VGA is
NVIDIA GeForce GTX 780
and I tried to use the Direct x 11 and open GL as the picture but same problem
Is there something to activate once to make the camera clip working automatically as 3ds Max
Message 6 of 13
damaggio
You can save your camera settings for the scale you like working, right above the camera attributes there a save preset button.
Are you on windows 10 or Mac?
Message 7 of 13
damaggio
And under preferences Cameras.
Message 8 of 13
damaggio
Also your perspective seems fine...is it only happening on orthos?
Message 9 of 13
Do you recommend that I change my VGA?
my VGA now NVIDIA GeForce GTX 780
Message 10 of 13
damaggio
I'm not sure...is this windows 10?...do you have any other machine with Maya?
Message 11 of 13
In fact I had windows 7 on another machine and I was having the same problem
Message 12 of 13
_sebastian_f
what you can try after setting you clipping planes like damaggio said is to "frame selection" shortcut "f" per viewport or "shift+f" for all views. also "default home" in the viewports "view" menu (followed by a frame selection depending on object size) helped me with issues like that when the clipping planes don´t update in the view correctly.
Message 13 of 13
thank you so much
