Hey,
I am having an issue navigating around my Maya viewport.
Any button that I press on the mouse just lets me zoom in and out, so basically I can not rotate or pan my view.
Just something I noticed, whenever I press the ALT key, there is a small minus sign (like what happens when you normally press the CTRL key.
Can not understand what this is? or why it is happening? Someone please help me out.
Solved by karan.malhotra. Go to Solution.
Do you have anything else, but mouse installed, like Wacom?
Have you tired to refresh your prefs? Exit Maya, rename userPrefs.mel in your \Documents\maya\2020\prefs\ to userPrefs.mel.old and launch Maya, try pan/rotate again..
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
You know what, I know it is not right but when I use the other ALT key (under the Caps Lock), it works fine. Strange
Thanks anyway
